Oil warning light
mike_s14
105
staffs
Bit off a daft question but I'll ask it anyway ;) ibiza 100pd 02
After resetting the service warning yesterday and it stopped flashing after start up
then this afternoon the oil warning light coming on, do I now need to reset this or is there a low level warning indicator?
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
this is low oil level and or pressure , have u checked the oil level ,make sure car is cold and level to get a proper reading , oil lights should scare u
mike_s14
105
staffs
arrrhhh :(
had a quick check and oil is on the level, but last week when the cam belt was replaced approx 2 litres had to be added to get it to the correcy level :whistle:
so some damage could be done, anyhow I reset the warning as I did with the service warning, will see how it goes
muddyboots
Still hanging around
Oct 16, 2002
5,739
Do you mean the oil warning *light* is coming on, or the word "oil" is appearing in the LCD display which shows up when the car thinks an oil change is due ?
