Sometimes the resistor can fail in the fan pack which means they can only turn at emergency high speed, not normal speed.
So you have no fan, get to 105 and then they'll turn on at hurricane speed. Then the process repeats once it's cooled down.
Do your radiator fans turn with your air con on? They should turn at a constant speed if your low speed fan setting is operational.
