Spoke to garage he says it will be fine but wanna check with the pros =) overfilled my oil was below min other day so filled up 250ml to just above min then got my top up oil today (same stuff had to wait for opie to deliver) filled it up about 600ml and on the dipstick it's registering as 3 maybe 4mm over max... as I say refused to start engine up just in case and rang my usual garage asked him he said it will be fine at that as it's burning a little anyway.
He then double checked with someone else for me who also said it will be alright.. its not way over just a few mm but im paranoid so wanna double check it with you guys... also thought these held 4.5l can't believe from below min to above max is under 1l?!
Thanks in advance,
Matthew
Thanks in advance,
Matthew
