overfuelling need a map
JimmyT
having a problem with the engine management light coming on because of overfuelling think it needs a stage two remap do you think this would sort it if so how much would you estimate i would need to save up for when i come down
tommy2008cupra
you cannot adjust fuelling on mk3 mate its something wrong with your car not the map, what have you got now ie what injectors fpr etc? have u put it on vagcom i think that would be my first port of call mate to actually find out what is wrong, how do you even know it is overfuelling?
JimmyT
my friend thinks it could be different injectors or FPR. THe code on the fpr is from a audi s3 225bhp engine so maybe the previous owner put this on. Could a map sort this out i have replaced the lambda and still getting the overfuelling error
tommy2008cupra
unless your ready to go stage 2 with mods then no, i think the fpr maybe 4 bar and if your on stage 1 or standard it needs to be 3 bar which is why it is overfuelling or could possibly be injectors?
JimmyT
im running BMC, forge tip forge split r, forge fmic, blueflame turbo back exhaust would that be ok for stage 2?
tommy2008cupra
ye that should be ok but not all mappers run a 4 bar fpr i know revo do, what is your current map?
tommy2008cupra
i think it was a lambda sensor code running to rich i think without a stage 2 map (revo because of 4bar) and 4 bar fpr this would run to rich try running it with a 3 bar fpr, pm daves ibiza if u dont have one
