Anthony haddad
Hey i am new member
and i wanna ask a question i have a seat ibiza 2013 its a coupe and i need to know if i can install a set of paddle shifters and what about air intake system is it possible ? Thanks in advance
-Bocanegra stuur (nieuw voor 120 euro Ebay)
-Airbag adapterkabel (50 euro bij de SEAT dealer)
-Ombouwen airbag en adapterkabel heb ik zelf gedaan, maar VAGtechniek kan dit ook voor je doen. Ook moeten die een draad trekken en het stuur aanmelden. Vagtechniek kan je van de prijzen voorzien.
No, alot cheaper. You can find a steeringwheel on Ebay. Here is a quote from the dutchguy that did it on his 1.2TSI;
-He bought a Boc steeringwheel for 120euro on ebay (can be found for 120~300, depends on your luck)
-Airbag adapterkabel, which can be bought for 50euro at the dealer, but some wheels on ebay already have those.
-rebuild, have to put the airbag in the new steeringwheel (if you bought one without), place the new adapterkabel, and then add some extra wire and add the setting in VCDS.
The spend around 200euro... (which is like 160pound?)
VAGTechniek is an enthusiastic garage, they do all kinds of OEM mods for people for reasonable prices. So you might have to spend a bit more at the dealer if you have it installed there.
