mark.r.cullen
Both doors needed the guide (not sure what it's called... black bar) bolts tightening up as they were a bit loose and were causing a clunk noise. That was one problem solved
However, I have noticed the passenger side door looks to be sitting low. When you go to close the door it rubs and has to lift itself up on the catch. You can lift the door by the handle and see that the door is actually moving up and down a fair amount.
The bottom door pin has a small bolt with a plastic cap, and this was loose to the point where this bolt was about to fall out. I have tightened this up as much as I can, but you can still see this door pin wobbling about when shutting / opening the door.
Is this just a simple case of a new door pin?? Hopefully?
