Passenger Windows Issues
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
hi peeps,
Got a problem with the passenger window........
Basically....when you put it up and hold the button and put it all the way up it virtually closes all the way, in fact to the naked untrained eye it is up.......
but if you press the switch up again it will go up a further 1cm or so. Bit annoying tbh!!!
It happens with both switches on drivers or passengers side.......
any ideas at all? its a bit annoying, as if not properly closed then it could leak!!
Rich
Ibiza Cupra
Motor????? Sounds like it runs out of puff and needs a second chance!!!!!
Tony 156
468
Thatcham
yeah, its the regulator or somthing. 70 quid i wont spend as winter is comming and have no europe trips planned any time soon.
Ibiza Cupra
surely one from a std ibiza will fit, must be a few scrappy's with some in??????????
Jan 19, 2006
1,024
fife, scotland
mine went in my old ibiza cupra sport a few years back and the scrappys couldn't help, its practically the whole assembly you need, the motor wasn't seperate. i'm trying to remember how much it was, about a hundred or somethin for the part alone. perhaps if yours hasn't gone completely then you should put up with it till it goes, but then it might decide to pack in when the window is down and that would be a right pain in the arse mate.
