Ply floor now test mounted to the car and needs a couple small mods so thats todays job (a bit more clearance for front tyres when on full lock and a tiny cutout for the very bottom of the gearbox bellhousing).
Hydraulic struts specced and ordered and should arrive start of next week - pics soon
Support cables arrived - really nice and high quality, pics dont really do them justice - these are military aircraft spec 1.6mm stainless cables (plastic coated) with stainless eyes swaged on the ends - very lightweight and with a breaking point of over 100kg each. Was going to use cables as used on sailing boats but apparently these are generally crimped together so are no where near as strong for a similar size. Also the stainless is a different grade which is chosen for corrosion resistance over strength. They really are very nice. 4 of these supporting the floor - should be enough; dont think we will be getting more than 400kg of downforce
The cables wont be seen externally - they will be fastened to the top surface of the floor behind the bumper and to the car chassis - they will suspend the front edge of floor from the car, the rear edge being attached to the hinge shown - the gas struts will put the wires in tension so that the whole thing does not bounce around (with a force of 25kg each side of the car).
The idea is that the floor will essentially be rigid when any downforce is generated, but if I should hit a big curb, the floor will be able to hinge upwards and not get broken.
Thats the idea anyhow.
Inspiration taken from this 911 (cheers Barny), which had the wires/flexible floor but not the gas struts (and also a pair of diffusers mounted into the floor which will be a future mod)
heres the first one mounted to the car - it will actually be compressed a smidge when finally fitted, by the wire teathers, so any downforce is carried on the wires rather than trying to pull the gas strut apart
ali angle bracket now to make to attach it to the floor
getting there - wires to attach now but its all got to come off first to cut a small hole for the very bottom of the bellhousing before I can get it totally flat for attaching the support wires
a bit extra clearance for the front tyres on lock will be added also while its off
tomorrow nights job
At full strut extension, the floor slopes down to the front by 2.1 degrees (front of lip at 80mm ground clearance, or just above the minimum 70mm that I have to run). The support wires will pull the front lip up by about 40mm so leave the floor dead level at 120mm off the deck. This will be the starting point for testing.
Latest: all wire supports now fitted - took ages getting it all completely flat. Into the last phase now which is fitting a length of flexible material between the bottom of the bumper and the floor - easy bit
