rallynut
280
Where is the cheapest for a PD cambelt kit it has to be genuine parts ive been quoted £108 for the belt and 2 rollers from the dealer and then need the metal water impeller water pump too.
Is there anywhere cheaper.
It doesn't fit all the 1.9 engines. There's a different kit for later ones depending on the build year of your car.
Did you contact David at Sere Motors? He'll give you the correct kit and at a cheap price aswell.
In fact I checked your posts and you seem to have a 2005 yr PD150. In that case thie item you linked to is incorrect.
yes thats correct its a 2005 150bhp pd,
its says it fits the ARL engine isnt that what my car has?
What it actually says is it fits the 1.9 TDi PD 150Hp ARL 1999-2002 (up to 1M-2-120000). Is that what you have? I thought yours was a 2005.
Apparently the part number for the timing belt kit on your engine is 038 198 119 A whereas the part number for the Ebay one you posted is 038 198 119.
ah i see,right i will check with the guy to see if he has anymore,also emailed sere motors
to be honest mate you would be better ringing david@sere and speaking to him direct and if i was you i would have your vin number ready, i got my kit from david for about the same price as the ebay one and with the kit from david you get a 2 year warranty which you might not get with the ebay one
i used german sweedish & french for all mine , was a continental make , and all came to about that
i only just found i can get trade there and at the dealers:wtf:
you always find that tho , when you dont need something anymore there are lots of options and prices !!
