PD intake / EGR clogging
muddyboots
Still hanging around
Oct 16, 2002
5,739
A while back I had the intake pipes apart on the Ibiza (the ones between the EGR and intercooler) and there wasn't the slightest trace of cack at all, just a thin coating of oil which is fairly normal.
Mind you I did disable the EGR quite early on by blocking the vac pipe...whether that's prevented any buildup I don't know.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
any chance of a pic of the hose u blocked off , the only valve i know of is the anti shudder valve , looks like a brass shiny thing on the back of the engine on top, where is the hose in relation to this
muddyboots
Oct 16, 2002
5,739
Was about to say there were some photos in the TDI FAQ thread, but it seems all the photos have disappeared.
Anyway, IIRC the EGR valve is in the same housing as the antishudder valve. The EGR has a round silver top with a vac hose going into it. Pull the pipe off, stuff something up it that's tight fitting, pop the pipe back on, job's a goodun. I found the engine felt smoother at light throttle, low rpm driving as a result.
Probably a good idea to back the EGR off as far as it will go with vagcom, so it's not running to much differently to what it thinks :)
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
something more to do this weekend
right in this pic , i have circled in yellow where the anti shudder valve connection is ,
gimme directions from this
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
i was always under the impression that was the anti shudder valve----starves the engine of air when u ignition off so it dies quickly n smoothly
muddyboots
Oct 16, 2002
5,739
They're both in the same housing as I recall, presume there must be a second hose somewhere underneath for the ASV.
muddyboots
Oct 16, 2002
5,739
If you look behind & below the EGR valve, you'll see a little pushrod thingummy that turns the ASV.
In the photo, just below the EGR and left slightly in the same pipe, you'll see the end of the ASH shaft, which runs front-to-back in the car. It gets operated from the rear. If that makes any sense at all !
cheshire cat
1,813
cheshire
if you wish to remove the egr valve doNOT try to remove the pipe on the ASH valve diaphram cut it and rejoint or it WILL break the nipple off and they are not available seperately this info :whistle: should really be a sticky
basstard
Dropping Cogs is Useless
Aug 24, 2002
2,746
Roma, Italia
How true,,, I broke the nipple on the antishudder valve actuator and they wanted me to buy the whole EGR valve,,, :wtf:
ended up repairing it by myself with glass resin and a nippled round plate coming from the N18/N75 communicator [the black and white thing].
If anyone needs pics/info on how to do this just ask,,, mine works a treat now.
