no, I ment between the 150 & 160. The 130 comes with a smaller VNT17 turbo (even though the 150 & 160 is also a VNT17).
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
devonutopia said:Hmm, those injectors are only £975 + VAT if you don't go down the fitting/remap route. If I got a set I'd be wanting Jabbasport to fit them for me, then tweak the map at the same time.
I like that.... "ONLY" £975 + vat....![]()
Allards use hybrid Garret turbos. On my ibiza i had a VT2 which was basically a VNT 20 turbo put in a VNT 17 shell.See here for the Allard turbo range.Diesel_Monkey said:I have a question about the turbo's used on the Seats. I keep seeing models simply, VT5, VT7 etc....
I dont want to assume that this is simply a Garrett VNT 15 or Garrett VNT17 (or should I say GT17V).
Could anyone explain the differences here between the Seat turbos and the VW ones, or is it the same model of garrett turbo with a different model number.
Matt
Pass, best phone allards and speck to them mate.Diesel_Monkey said:I see, a VNT 17 modified to run VNT20 spec should be able to go to 250 hp, why have they listed the VT2 as only 220 hp ?
One more quick question, may I ask what spec the VT3,4,5,6 & 7 is ? The website doesnt go into any detail on this.
thanks, Matt
your ment to be at work mate NOT surfing the web.devonutopia said:220 is probably a realistic limit given not many other mods with that turbo. I run the same Allard hybrid in my PD130 converted Fabia, and dyno'd at 221hp fly / 190hp ATW depending on the roller.
This is with an FMIC from the same company. It won't go above 221 now without something a little special, i.e one of their bigger turbos or injectors. I feel with injectors though the VNT20 hybrid will go further. I'm only using the fact it was able to push 2 bar consistently to back this up, and at this pressure though, the oem pd130 injectors couldn't cope, so power dropped. Backed down to 1.8 bar and its OK. Hoping new injectors and a remap might see in the region of 230+?
I didn't realise the race PD nozzles used to be circa 2k? EEEEEK!
Maxcars - those injectors are standard (AFAIK) pd130 injectors for the pd100, which combined with the oem vnt-17 from the pd130 will see 180bhp+ from that engine, which is impressive.
devonmikeyboy said:your ment to be at work mate NOT surfing the web.![]()
devonutopia said:But when you're being made redundant in 6 weeks ish, and all the work you had to has been centralised and moved away - There's kind of sod all to do all day, and with regards to using the internet at work, its more like, "Don't give a f***!"![]()
Perhaps I should be job hunting rather than being on cupranet though.![]()
