Petrol in Diesel :-(
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
How did you manage that?!
Don't answer that, I know how to fill a car up ;)
No idea mate, my dad did put £5 in his new disco but realised and topped up with £70 of diesel!
kris_tdi
108
did you start it?
if not then you will probably get away with sticking a tube in the fuel tank and sucking it out.
RichIbizaSport
Says Bye! x
Apr 29, 2007
224
Hull
www.facebook.com
I did this the other day, was talking to my friend at the time and didnt realise :-( . I put 3.7 litres in. Rang my uncle (mechanic) he said fill it to the brim with diesel and it should be fine. I did, almost used the full tank now and there hasnt been a glitch
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
if its full suck it out and fill with disel should be fine, if u have started it then all I can say is unlucky
Jun 7, 2006
2,983
Norfolk, Norwich
remove the tube at the pump it should flow out if its any thing like my fiat was.
might run rough when u first start it if some petrol got through to the engine... all i can say is unlucky mate. happens to the best of us...
Smee
reedbradshaw
Spireite till i die
Oct 6, 2006
199
chesterfield
happens to the best of us ? more like the mentally challanged us !
:p
mexicorich
Newbie
Apr 17, 2006
261
Hartlepool
Right, for anyone who needs to know.
The fuel lines easily come apart. They are clipped togetherand are designed to be unclipped, with a release button on the female side of the joints. There are joints just infront of the fuel tank that are ideal to split with the back of the car lifted up and a container underneath.
I used the lift pump in the tank to pump the fuel out. Access gained under the back seat. Electrical connector has four conections. The two outer are the pump and the terminal fed by the brown wire is earth.
Connected 12V to the outer terminals and pumped all fuel out of the tank via the disconnected black 'feed' fuel line. Then reconnected the feed leaving the return disconneted. Put another gallon of diesel in the tank and again ran the lift pump to try and prime the pipes. Replaced the electrical connector and started the engine up letting it run at idle until the gallon of fuel had worked its way through and been pumped out of the still disconnected return fuel pipe.
Reconnected the return pipe, added a futher gallon of diesel and drove the car back to the filling station.
PD130 running like a dream again!
I first called the AA by the way. They could only offer to take the car to the nearest approved centre (actually the filling station I was at!) who were then going to charge me £200 for 15 mins work and fuel disposal!
vinocolapso
119
Oxfordshire
Dont drive for a while then mate!
Hide your keys with a non driver & get drunk for a few day :beer:!
Then when you have a raging hangover, banging your head against
the wall over wrong fuel wont hurt as much :banghead2:
How much did you put in & how empty was the tank?
Have heard/read somewhere that diesels will burn almost anything!
Chin up!! :runaway:
