Nov 2, 2004
9,334
South Wales
What do these look like? I just ordered some from ECP and they look like rubber doughnuts. 7.50plus vat. Sound about right?
Any help would be good. Cheers.
Yeh same here too, please can you post the part numbers. Mines been knocking for a while so i will order them from ecp n see if that cures it.
I got the top mounts from here...
http://www.vwspares.co.uk/ibiza99_suspension.php
Part bnumbers (taken from above site)
Front
6N0412331E
(6N0412331D)
Rear
Replaces OE Ref:
191 512 333 (Lower)
191 512 335 (Upper)
Top mount bearings... (taken from the box)
6N0 412 249 C
Can someone check these with etka to see if theyre ok first.
Hope that helps.
All done. Bye bye clunking. :D
Camber is way off now because i think i put the top mounts back in a different way i.e rotated from the original position, plus the fact that the bearing raises the suspension a little has made it all over the place. Will probably whip it off after a drive and see if i have rotated the top mount.
Sorry to hijack but would you reccomend i fit these when fitting the coilovers i just bought?
