All wired up off the Key now, rather than crock clips as previously
No spark was as a result of me neglecting the fact that I need a hall sensor to actually trigger the coil.
Wired in my 'new' relay board into it's new box, and hard wired all the connections.
Just wanted to test that it worked, Key in ignition, 1st position (whiiiiiirrrrrrrrr) Fuel Pump primes, ECU 'wakes' up, reads all the correct values from all the sensors - check TPS is zero'd (it is), check that the base map I'd uploaded and all the constants are there (they are)
Great, lets be amused & turn it over.
Final notch on the barrel & CLUNK
reset ECU - 10.3V doh that's not enough to turn a starter
Go through the garage & find two flat batteries & remember I've loaned out my charger to a mate.
Never mind....
Can't decide how stripped out to have the inside (carpets / no carpets etc)
Fan's got a bug, I can get it blowing, but only a little breeze - not what I need, so I need to get in there & have a look at what's blocking what.
Had some mechanical setbacks - while I was fettling with putting the new steering rack bushes on the car fell off the axle stands (god knows how I managed that) - but I got out fine before it went. shook me up a bit, and the down side is that currently it's wonky on the drive
I need to roll it down a bit, then straighten it up a bit on the way up, but the steerings not connected, or handbrake, or rear brakes at all for that matter.
All good fun though
