donovan2123
352
Oxford
Hello people so i have just bought this >
http://cgi.ebay.co.uk/PIPERCROSS-VI...ryZ36680QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
the 1 i have bought is not made for my car but i am going to mod the pipe to fit!!
anyways i was doing a search and i noticed alot of people complain about pipex due to them being oiled filter???? why is this???
another thing i wanted to kno is when i get it i wanted to place it as close to front as possibale if not then i want to have like 3/4 feeds for cold air?? any ideas where would be best place for feeds and viper???
DAM thats expensive i wont bother for that sorta wonga m8,..........
the maf has a sensor inside it oiled filters may leak a wee bit of the oil on the sensor there for f*****g the maf right up.......u want a dry filter one m8
lol didnt pay that amount payed £60 for it. How will i kno if this is a oil filter? will it def drip on maf even thou i was going to locate filter away from engine and have a pipe going from filter to engine?? i wantd to locat filter to a source where it can get alot of cold air easily with out the filter gettin wet when it rains???
pipercross are oiled not very heavy tho n you should be ok
but if u wanna mke sure wash it with the cleaner n leave it,dun put any oil on.
a quick tip if u dun want your filter to get wet you can get like a realy realy fine mesh bag from k&n that slips over your filter,,,get one of those n spray a realy fine amount a silicone spray over the k&n bag to repell the water ;)
buying service stuff for car:
bought:
ibiza front disks
ibiza rear brake shoes
performance ht leads
spark plugs
to buy:
oil
oil filter
front brake pads
anything i have missed??? also what oil is it which is best ???? and cant seem to find brake pads on ebay could someone have a look and find them please???
meaning i wont have to worrie bought piper cross oil filter wont affect maf cause there isnt a maf????
Anyways help needed for above stuff
so what is the oil called?? the best 1??? also how much do i need??????
what brake pads do i need??? and have i missed anything of the list from above
Not sure what upgraded pads there are for the 1.4 now - but you will need them.
the 239mm discs get hot so fast - they're verging on dangerous
Is there a need for loads of cold air feeds on a 1.4.
There's more than likely going to be no performance benefit / deficit no matter where the filter is located.
I'm not opposing the mod, as it will probably give a nicer sound.
pipercross garrentue a increase in acceleration not alot like half a second but still thats something they tested this item with a saxo 1.6 and that gained like 2/3bhp
