Bagpuss12
46
Morning all. I have a 2015 FR estate which requires a new air con condenser. There was a piece of protective plastic that secured underneath the rad which protected it from debris etc (which is not the main engine undertray) however mine was ripped off/damaged and wondering if these can be bought separately and if so, from where as I can only find the engine undertray?
I've had a look for you under "body" and there are obviously "spoiler" which is probably not what you need as that is fixed to the front bumper, but in the parts group before bumpers, there are bits that get called "water boxes" a central one and a small one on each side - does that in any way tie with what you think that you need?
I don't have a Leon but I do "look after" issues/servicing on my older daughter's 2019 Leon Cupra 290 - so I can't "jump out" and check to see exactly what you are referring to.
I hope that this helps - a bit!
Reactions: Mr Pig
I don’t think so but cheers. Looking at an exploded diagram I think it may be described as wing of the spoiler, bottom?
It is an easy job to replace. You do not need to remove the bumper or main undertray.
