Poll-fan fuse on battery melted/replaced or not?
My fan fuse on battery has melted/been replaced
  • yes
    Votes: 108 70.6%
  • no
    Votes: 45 29.4%
  • Total voters
    153
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
In conjunction with the thread running re fire.
How many peeps have had this part fail or be replaced.
melted fuse holder on the battery. Controls the fans amongst other things.
Rick-24
443
Well surely they should replace the radiator fans aswell if thats the cause lol
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
mine did it, it got replaced under warranty, new one has'nt done it since, same fans, only thing changed was fuse plate.
Jun 29, 2001
537
Surrey
I've voted no but from looking, water has got inm there at some point.
It's only a matter of time before it'll need replacing.
Must say, this fire thing has really caught my attention and I am concerned!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
16 yes vs 3 no so far
Not good odds is it so far..
C'mon SEAT UK.... you allegedly read this forum ...
84% Failure rate on Customers Feedback.
Pretty conclusive.
"hello, is that watchdog?"
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
corrosion = higher resistance = more current for the same power consumption = melting..........
Big question is why? and what are VAG/SEAT UK going to do when this results in fire?
:whistle:
Rick-24
443
soo really its cause by corrosion, water maybe gettin on the contacts. well i did notice my battery terminal on the negative is kinda gone abit corroded.... like white scum on it ... i will have got clean that up me thinks:blink:
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
i am not convinced it damp. its in a hot engine bay, has no means of easily getting water onto it....
galvanic corrosion however from 'iffy' plating on some parts etc and that to me is just as likely if not more so.
worth checking for earths and good contacts, as small potentials can create the cells from which corrosion starts.
Sim
who?
May 24, 2001
1,700
Budapest, Hungary
www.ignitron.net
My A/C stopped working. I knew that it isn't the gas or some other malfunction as the AC symbol wasn't blinking. Opened the fusebox on the battery and one of the three green (!) 30A fuses was melted (a bit of the fusebox itself too). It isn't a severe damage, replaced the fuse (applied some contact spray on fusebox's contacts) and will check regularly.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
What about sticking a clean one on & lubing it up to prevent oxidisation?
assuming the fan draws less current than the fuse rating....
Shock_Xe
mine happend the other day, temp warning came on popped bonnet and fans wernt going, immediatly thought of this, pulled fuse out and swapped it and they came on, looks like plastic started to melt on fuse anf fuse started corroding. Gonna get new fuses tomorrow
