mal22938
Hi all,
Anyone know the whereabouts of the A/C pollen filter on the Altea? Can't see it in the engine bay so is it hidden inside the car?
Cheers, Oscar.:confused:
Yep,
Its under the glovebox. There are some torx screws that undo the panel below. Then you can see a sort of cover. You need to slide one bit and then the filter pulls out. Put down a sheet as you may get lots of leaves and things out. Mine was quite clean still at 16k.
