Pollution Warning Light -Help!
Harpic
The warning light that the book says is the Diagnosis of pollution has come on anyone know what this means-is it the Lambda or what? Cupra 20VT -2001
All help gratefully recieved.
Mitchy
TTRS
Oct 12, 2004
2,310
The tern diagnosis of pollution is totally mis leading.
It is your engine warning light. It could be a possibility of 1 fault from a list of hundreds so its impossible for us to tell you what it is.
The ecu needs reading to determine what fault you have. The fault will then need clearing after problem has been fixed.
If the car is still driving fine, its probably a dodgy sensor.
A Search would have helped you mate, been covered thousands of times:)
Harpic
I would if I knew how.
Will probably have to take it to Awesome as I live fairly close and get them to do diagnostic-unless someone can tell me another way?
Harpic
Sorry am fairly new to the site but will know for next time-thanks
Mitchy
TTRS
Oct 12, 2004
2,310
You can buy a fault code reader from ebay, £30ish.
This will allow you to read and identify the code and then clear it, or you can find someone who has vagcom to identify and clear the code for you (For free)
Or you could pay a dealer/garage/awesome £40 for 2 minutes work in reading code and clearing it for you.
Where do you live? Im sure someone could help you out.
I have vagcom and fault code reader but down in Shropshire, so probably miles away from you.
Mitchy
TTRS
Oct 12, 2004
2,310
Quick fix is to disconnect battery for 10 minutes. Reconnect and this will reset your warning light.
Fault will still be stored in ECU but it will free up the engine warning light. If light comes back within a couple of days, it will be the same fault recreating itself so you'll need to take further action and replace the faulty part.
If it doesn't come back on, then ignore it.
Harpic
Cheers for help guys will have a look on ebay and also try dissing the battery.
I live in Bolton so if anyone near me has VagCom any assistence would be appreciated.
Failing all the above I will book into Awesome next week some time.
What is EDC were you all order parts from?
