pj i think its a different code.
the one your thinking of is something like 'engine speed exceeded!! warrenty void
ECU is probably backing timing right off, this will effect boost. My Apexi is at 90% most of the time due to a weak actuator I have and the amount of boost I run. You on self-learn duty? Apexi starts to learn at throttle positions above 85%. Mine throttle is at 100% on the avc-r without pushing my foot right through the floor.
Need to log timing and AFR.
its engine speed warranty void not boost.
Is apexi in learn mode if its tripped to run requested boost or fixed duty cycle.. fixed should be fixed after all
max boost exceeded is its gone beyond what it was expecting (in map) at that given moment.
dbw weirdness going on I suspect with not all controls under Me7's control now.
request boost of 1.3bar?
It doesn't matter if the road speed is out, as it will be uniform. 60mph will always be the same amount of km/h in the avc-r for example. You should set you gear values though. Just drive the car and copy the value on the left of the screen into the setting point for each respective gear.
To my untrained eye I don't see much wrong with that log. timing pull doesn't seem excessive and the areas where actual and requested boost differ loks like you might have been just coming off the throttle?
Others will chime in with better interpretations I'm sure.
You really do need to find a longer road and really get on it to know what the engine is doing at the limit. Log overall timing too and lambda.
Also if you can take a look at this guide it makes it easier to read and see trends, or just post an excel screen if you have it.
http://forums.vwvortex.com/zerothread?id=3667719
Thing about start duty and feedback values too. All in the manual.
Bill, if he is running a separate EBC, does it matter if the requested boost is off since there is no N75 control or should the ECU request the max boost set in the EBC by JBS?
Thanks Bill, I forget about the ME7 throttle control as I have the cable type. What my foot tells it to do, it does!![]()
I mention it as deviation is deviation, and the ecu still has control over the throttle position and can close it when its trying to operate a request which is outside of its control now. I think he said his throttle angles were not 100%, and this I believe is an adverse effect on part load, part throttle application when using an external controller for boost.
Just because you put the pedal to the floor does'nt mean the throttles fully open as Me7 is trying to run best angle for requested laods. (which are now frigged beyond its control)
I noticed that when I floor the pedal, the throttle shows 100% (AVCR) then starts to drop down like to 80 something %...
I guess what u said is happening, the ECU is adjusting the TB itself even tho I have it firmly pressed down because of the difference in requested and actual boost?
Something just doesnt feel right
Also I put in a brand new 044 pump thinking it was faulty and the new one was much quieter on priming and even so when the car was on compared to the old one but now a couple of weeks later it sounds just as noisy again, and I;m sure the car doesnt pop and bang like it was when I got it back from JBS the other week...
I am wondering if i'm getting a fuelling issue aswell
Wonder if what u mentioned Bill about the original fuel lines being able to blow but not suck causing me a problem...
Can anyone confirm when the pump is on, should the sound be uniform all the time or does it fluctuate, e.g not when on idle when u turn heating on (momentarily power drops) but this happens constantly, the pump noise goes up down up down, not louder and quieter just whining high pitch then low pitch.?!/!/?
Thanks HTC I changed the values on the gear judge, need to see if it makes a difference...
Only thing is, I like the fact I can play around with the avcr settings, but was hoping it was all perfectly set when I got it back...
