Poping the back seats out?
depresion
484
How hard is it to remove the rear seats? Is it like older VWs where once you lift the seat base out there are some clips you need to push with a screwdriver and the backs then pivot up at the sides so you can slide them out from the center?
croakey
tommmineh
1.2 POWER
Feb 28, 2005
721
Sheffield/Rotherham
^ :happy: :happy: :happy:
Its a piece of piss, lift up the bottom bits first and they just unclip, then each side of the back you screwdriver the little latch type thing and then slide them off the centre bit.
Only prob is you need to unbolt the seatbelt harness for the larger back piece
depresion
484
So yep just like on the old VW range (probably new VWs as well) I guess if it works why change it.
Guinness
Finally got the BMW
Nov 29, 2006
4,421
Newcastle
hada look when fixing the seatbelt looks pretty easy have 2 say the bottom bits come out dead easy, didnt try removing them as I managed 2 fix the belt with out undoing the seatbelt. Anyway GL with it matey
