Porsche design 90 on a mk4
wenman
Red Ibiza 1.8T
Mar 28, 2009
1,094
Cheshunt
Can anyone tell me if these will fit on the Mk4 Ibiza?, would probably look at getting 6J front 8J rears?
I know PCD adapters would be needed but will the wheels foul the arches at all?
Nov 24, 2007
543
Swansea
Check this link out:
http://www.1010tires.com/WheelOffsetCalculator.asp
Calculates how the new wheels will sit in comparison to you'r current wheels by using wheel width and offset. Standard offset of the D90's are ET52 so with the use of adapters (e.g 20mm) new offset will be ET 32.
Worth checking the centre bore of the D90's as not sure if they match up with the 57.1 of the Ibiza, and depends what brakes you use as clearing them might be an issue.
P.S- D90's rock.
wenman
Red Ibiza 1.8T
Mar 28, 2009
1,094
Cheshunt
Yea I did think that about the 6 inch ones, I have seen 7.5 just got to work out whats going to fit on the car,
thanks L5FLD.
