Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Hi
Could a air leak trigger off these codes below the top one?
Last thing I had done was the intake manifold taken off and polished.
I am getting a engine smoke test done soon off a member off here.
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
17608/P1200/004608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
No I didnt
Reading what some one PM me I think it is a air leak.
Last mods where intake manifold taken off and polished (maybe it wasnt fitted back properly?)
Forge FMIC maybe hose clip is lose or stone damage on the FMIC it's self?
As you look down on the manifold from the front of the car underneath the left hand side (LHS) are 2 nipples.
Each has 4mm pipe, with one going to your fuel pressure regulator (FPR) and one going to your N249 (or DV if its bypassed)
