Possible boost leak?
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
Afternoon all,
have a small problem with my cupra, maybe someone might be able to help.
I've fitted the new split-r dump valve to the cupra, and i'm pretty sure this is causing my problems, or something i've done whilst setting it up!
basically, if i only put a small amount of throttle on, you can hear the dump valve as if there's boost leak, but as soon as you put a small amount more on the throttle, it immediately stops and the turbo spools up... maybe the split-r spring isn't setup correctly??
Also, sometimes the car DOESN'T come on boost at all, drives like a 1.8 N/A car! Turn the engine off, turn it back on, and boost is back. very strange... any ideas guys?
cheers, rhys :shrug:
May 2, 2006
2,758
is this only since you changed the dv to the split R?
if so, check you have set it up correctly etc ..... (needs setting up to run right)
if not, start checking vac hoses, ic pipes etc etc ....
B3NPM_Cupra
Money = Power!
Dec 9, 2006
262
Tamworth (West Mids)
i had the same with my split-r valve mate. i found that adjusting the spring didnt change anything, by all means give it a try. but in the end i did the n249 bypass and all is sorted now no probs. hope that helps.
May 2, 2006
2,758
like i said .......... check your vac hoses
you probalby got lucky and the vac hose you removed from your n249 was probably your fubered one ;)
SWANSWAY CUPRA Dealership
