Possible gear problem (DSG)
Apr 30, 2019
8
Ok try & keep this small, recently purchased & noticed when I’m in D sometimes it doesn’t change gear or seems as though it doesn’t want to even though the car holds high revs then eventually changes after I put more acceleration down, is this normal?
Reactions: MifSal
MifSal
48
31
mine does the same but only holds til about 2600-700ish rpm probably and then changes. it should be normal tbh
Reactions: dannycakes
futurelogic
38
Every DSG car I've had has done this from a cold start. Silly question, but it is in D and not S?
Apr 30, 2019
8
I’ve also noticed when I accelerate hard in D the engine light comes on is this normal it’s only briefly in for a few seconds (flashes) then stops & doesn’t happen again.
prelude1992
46
KUWAIT
Are you sure it's the engine light not traction control light?!
Regarding the gear shifting , is it on hot weather happening or at any weather conditions? Gear megatronic may cause this issue I guess
seatram
120
63
Ilkeston
I've only been driving in a DSG for a week, but I've noticed this too, if you let go of the throttle a little bit, it should change up and cruise a little easier.
