Power consumption warning
Deleted member 103408
At a guess the car is telling you its going to start to protect the battery by closing down some of the high power usage items (Heated Seats, Heater/air con etc).
Was it when the car was sitting idle or just on ignition tunred on or when the car was being driven.
Reactions: Theporter
Theporter
141
57
I just noticed it when I started it up earlier
Is it because I do a lot of short journeys
As i said dont know but there are a number of systems in place to ensure the battery has enough power to start the car.
If you car has not been out for a long run recently might be worth a run just to charge the battery up.
Theporter
141
57
Dealer reply
It's not so much a warning more advising you.
It's advising that there is a lot of consumables being used such as heated seats or heating or sat nav and in car technology
Reactions: Mystery290
Yes Stop start has voltage limits so that it is not being used when car is using lots of power and or the battery is low.
Do you have a lot of stuff on that would explain the high usage or is it just a low battery.
Do you have access to OBD11 or VCDS to see what the system thinks the voltage is and if there are any error codes being shown.
I understand the point of the message but cant say I have seen many people complaining about this might be worth another chat to see why they think it happens so much when you are not using lots of stuff.
BoomerBoom
702
252
How old is the battery? If mainly short trips during its life then it might be done at three years or even less.
zeffania
479
159
Think you need the key in, but the ignition off if I remember correctly. Worst that happens if you get the wrong combination, you reset your trip. I have done this a couple of times, lol
I have tried but could never get it to work always use OBD11
