Hello alll last night I was driving back from the girlfriends house and the steering seemed to be very heavy at low speeds . And also when turning into a side road which is about 90 degrees it seems like it couldn't react quick enough I was going to check the power steering fluid when I get chance which i located under the battery I believe ? Do I need to remove the battery ? Also is it worth checking out the battery as it's the original its a 2006 fr tdi.
Thanks in advance
Matt
Thanks in advance
Matt
