Pressure Test Help
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
So I want to do a full system boost leak pressure test.
I have made up an adaptor to fit where the MAF goes but what pressure do I charge the system with ?
I know I need to remove oil filler cap , although I have a vent to atmosphere catch can.
What else is needed ?
Leon20vt4
939
683
I have no idea but this sounds cool and I will be watching this thread... hope someone can bring some good info! Good luck mate!
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
Well, the results are in and they are not good, not good at all.
So essentially the first attempt to do a whole system pressure test failed ,found the IAT sensor in the throttle body leaking badly so fixed that.
Next it still wouldn't hold 15 psi , it leaks down very quickly , tracked it down to the dipstick tube , so with that blocked and the oil filler cap in place it still wont hold pressure.
