djmozibiza
06 Leon 1.9TDI Stylance
Apr 7, 2007
51
Stoke
www.youtube.com
car has started miss fireing and has had a lack of power, this started few weeks ago, and has got worse and worse, thought it mite of been the plugs go swapped them it was ok for a few days then continued getting worse, and today has jus totally cut out lost all power, then wudnt start, eventually re-started and got home got the vagcom on the car, i havent got a clue what any of it means so hope someone can help
VAG-COM Version: Release 409.1-US
dans motor
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
Controller: 03E 906 033 D
Component: 1,2l/4V SIMOS3 00HS4342
Coding: 00061
Shop #: WSC 06402
VSSZZZ6LZ3R038956 SEZ7Z0B1671780
5 Faults Found:
17811 - EGR System: Regulation Divergence
P1403 - 35-10 - - - Intermittent
17811 - Shareware Version. To Decode all DTCs
P1403 - 35-00 - Please Register/Activate
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-10 - Please Register/Activate - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC
Controller: 6L0 820 045
Component: Klimaanlage X0840
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to B+ - Intermittent
01596 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
01271 - Shareware Version. To Decode all DTCs
29-10 - Please Register/Activate - Intermittent
28-10 - Short to B+ - Intermittent
28-10 - Please Register/Activate - Intermittent
help if you can, thanks, dan.
no 3 coil pack maybe seing as how it says no3 cylinder misfire detected
the coil pack is what plugs onto the spark plug
not sure on the location of no3 but swap them out in turn and fingers crossed
no3 is the 3rd from the left , swap the coilpack from say no1 and drive ,
relog and if the fault code says no1 cylinder thats your gremlin
always handy to keep a spare coil close by
