Problems caused by bad coil pack
gnormy02
Full member
May 3, 2007
108
Hi i have just started having problems with my cupra.
Could anyone please tell what problems come with a bad coil pack.
My car is sounds lumpy while acelerating and has lost power.
It has a ko3s hybrid turbo and i dont know if it is that or the coils.
Any help would be good
Thanks:help:
Dec 3, 2007
2,475
cardiff
coil pack! Can check it buy unplugging 1 coil at a time. This will give you a hint as to which one is broken. The one that doesn't make a difference sound vise. Or can find someone with vagcom
gnormy02
Full member
May 3, 2007
108
cheers.
I have also noticed that the management light is flashing while driving.
It sounds very much like it is running on 3 cylinders.
So possibley coil.
Has anyone else had these same problems with coil packs?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
yuo are definately having the coil problems.
I suggest you just use the ones the stealers supply, as I had a faulty one and the tripple A came and put a new one in. However the coilpack had 1 number difference to the original ones, and although it worked it kept up the management light and code...
so just use the regular ones is my advice
gnormy02
Full member
May 3, 2007
108
i got an original one and it has done the trick.
It cost £25, is that about right?
