Jan 9, 2008
363
Sandbach
Anybody else having problems running any of the shareware Vag Com's in the 64bit version of Windows 7?
I've tried both 409 and 311 in XP SP2 compatability mode, and running as an admin, with no luck. I click on the icon to open the software, the mouse curser changes to a 'loading' one, and then nothing.
Any solutions out there?
Hi this is what I did then run in windows XP mode.
Run the Program Compatibility Wizard
1.
Open the Program Compatibility Wizard by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2.
Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Hope this helps
ive just had the same problem. my mate done all the instalation of the software an set it all up but i know he downloaded a program called virtual box which lets you install windows xp aswell as windows 7. you do need windows xp cd for this obviously.
then we just installed vagcom on the win xp desk top and it worked first time. :funk:
hope this helps. if you need more info ill get my mate to explain in more detail
