programming immobiliser/key fob
TINCAN
246
MK
is the immobiliser 'chip' not the glass tube part ... not sure what the 'small magnet bit is maybe need a closer look then
So i am replacing the fob but using the old key.... do i jsut remove this chip part and program the rest as per the book?.... Bascially the old key fob is splitting so needs a nice shiny new fob... if its that easy ill just take out the old chip insert into new and thats it..... is the glass tube the part ...
Copra
Used To Be "mk4polo"
Feb 7, 2003
2,616
Hampshire
oh yes it could well be. what age is the car?
where was this bit located? down by the base of the key? if so then yes it iss the immob bit :)
TINCAN
246
MK
its a 52 plate, glass tube is near the key base, so would bascially stay with the key and the 'U' shaped piece of plastic at the base of the key. The piece then plugs onto the new key fob part
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
immobiliser 'bit' is either a small glass tube or a black chip
both very small
if you are adding a new key and have no use for say a 'spare one' simply add the chip from the 'working' key to the new one and no program required
however if you have a complete new key to be added on its own it will need reprogramming
TINCAN
246
MK
yeeee haaaa so all i will need to do is set up the central locking bit by following the instructions in the manual?
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
pretty much ye
what car is it ?
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
drop me an email and ill forward on the list i sent somone last week for programming the remote bit
TINCAN
246
MK
Nice one Flapper... gave it a try this morning and sorted the central locking, alarm within two minutes following your advice..... then checked that it would start and all okay...
Thanks mate saved me a fortune :D
