Project rear seat heating
cairus
1,429
519
Good morning.
Thanks to the new seat configuration, I now also have heated rear seats, which I would of course like to activate when needed.
The part numbers are from the Octavia 5E facelift:
- Control unit for the rear heating mats 3AA959772 with matching mating connector 6Q0937713,
- Buttons 5E0963105A and 5E0963106A. I will provide the item numbers for the matching connectors later.
I'm currently installing the buttons.
I'll probably install them to the left and right of the panel. There's the most space behind them.
Mo_86
294
106
UK
Good morning.
That's amazing!
cairus
1,429
519
the article number of the plugs for seat heating rear left and right:
8W0971636B
8W0971636D
cairus
1,429
519
the rough adjustment has been made.
Reactions: gabz
cairus
1,429
519
So, the first implementation. But I'm not entirely satisfied yet. It's enough for a start. Now, as far as everything goes, let's wire it up.
Reactions: Chariot and Mo_86
cairus
1,429
519
The control unit with plug and a few cm of cable for the rear seat heating has been delivered.
Reactions: Slavixs
gabz
9
14
Amazing project cairus. I like retrofits like these. I just didn't get what rear seats (bench) do you have. Standard leons or you swapped them for something MQB related?
cairus
1,429
519
The New is from Octavia 4 RS, Ergo Line
Today I received several connectors for the rear seat heating. I'll let you know the item number.
Reactions: gabz
cairus
1,429
519
The cable harnesses are being manufactured... the module will be installed in the center console. There's enough space and it's easier to reach than in the trunk behind the trim.
Reactions: Slavixs
cairus
1,429
519
Good morning. The seat heating buttons are wired up, but terminal 58d and terminal 31 are still missing for connection. Next comes the wiring harness for the power supply.
Reactions: Chariot
