Ram Air filter
-pseudonymous-
681
Hi Guys. Im currently running a Green dynawist which has seen better days. Ive heard some good reports on the Ram Air Maxflow filter, but how does its compare to the Green Dynatwist? Is it worth changing and will it give a louder induction noise and dumping sound?
Also can an anybody tell me where i could get my hands on one for my Mk3 Cupra and how much it would cost.
Cheers. ;)
-pseudonymous-
681
Thanks Bill. Nice lil motor and sounds great!
I dont think i'll be needing a breather as i already have a green one. Will be in touch in the new year.
Cheers and Merry Christmas! :funk:
joe_cupra
alr8 bill..
im going to be buying a air filter off you within the next week or 2 what would you recommend out of the ramair and the dynatwist? id decided on the dynatwist until i watched that lupo clip,want the 1 that lets you hear more of the dumping noise really..
cheers
Joe
Deleted member 9043
do you have a picture of the "ram air" kit
he sounds verry good but im wondering what kind of fitler it is,
i believe its a cotton filter? and its on a alu pipe or something?
grtz
Deleted member 9043
ok,
its louder but more important how he does the job on a k03s setup or something?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
grtz
here's one on a mk4 cupra
Its a foam filter inside, steel mesh reinforced.
very similar looking to Dynatwist (which is cotton gauze)
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
bill, can you buy just the filter fot it, as opposed to the whole setup?
Also do you know what size the neck of the filter is compared to the dynatwist?
cheers
Olly20VT
1,234
Stroud Glos ,England
dose anyone know why that would be louder, surly if it lets more sound out would that meen it lets more air in? or have bigger holes in it wich would let more crap in than the dynotwist, not slagging eather off, but dose make you think.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
cheers
Neck size depends on car fitment... (smaller ones have insert which is used to make up the gap) - 70mm small, 75mm larger
Filter as in whole unit in its ally case?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Foam looks to be free-er flowing, hence noise, smaller filter in the housing compared to Dynatwists.. (more space in housing, making it sound louder?)
Filtration is dealt with by sticky polymer coating to catch dirt etc.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you will need to measure the Dynatwist neck size in the base and size a filter (RamAir open cone) to suit, if there's one the same size.
Deleted member 9043
speaking about airflow/performance
on a k03s of BT setup this ram air vs dynatwist?
what do you recommend and is this filter maf friendly?
grtz
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
MAF friendly as each other in respect to no coating comes out of them.
careful mounting req'd on either to avoid unwanted shocks & vibrations.
Remembering MAF's are a shite unlreliable device anyhows.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Hmm think i'll get the dynatwist filter out to take a look then!
Bill would i be able to order just the filter from you, once i've sorted out the measurments of the filters etc!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
I dont think RamAir's filter range is very wide on normal fitments compared to Greens..
see what the neck size is and I'll see whats listed (but not a lot on the info I have here currently)
