Ramair install help
Manesh gurung
26
hi
tried to install ramair induction kit which all went well but air vacuum hose did not reach to the kit.
Do I need to buy longer hose? or is there any solution? i see the hose part is attached to some part of the engine which i do not know if that can be clipped out or not. any help pls.
and if i need to buy the hose what mm size would it be?
TheSwede
371
211
Sweden
You need to buy a longer hose. The hose pipe/tap on engine is nearly visible on your pick.
An alternative is to add a hose to extend the length. Then you will need a small “pipe”/tap to put into the existing hose. On my Cupra the hose is a bit longer than yours.
/Peter
Reactions: Manesh gurung
Manesh gurung
26
/Peter
thanks for info
do you know what size it is? i cant seem find online or im just too dumb
Manesh gurung
26
I just checked my Golf Alltrack 1.8TSI. Same short hose as yours. Don't no the size. By one for cupra 300/ Cupra R 310 2018.
thanks man
time to search i guess. cant seem to find that specific part. or im not putting right term.
stock filter back -_-
had fight with that top clip to put back jesus
TheSwede
371
211
Sweden
Order it from nearest VW /Seat dealer. If its VW order it to a Golf R 2014 (same hose as to Cupra 2018) ;). Inexpensive I guess!
Giuseppe Busso
Ioannis
Jan 29, 2021
91
53
Greece
hi
@Manesh gurung
Did you find dimensions for the vacuum line? How many mm is?
Giuseppe Busso
Ioannis
Jan 29, 2021
91
53
Greece
i was not remapping or taking advantage of the new kit so just went back to stock but had fun man sounded good as well when i had it.
I bought a RAMAIR kit at a very good price yesterday. It was second hand but in great condition with only 5K km's. I was already stage1 (100oct) mapped since December of 2021. Stock airbox with a K&N filter, MST turbo inlet/hose and mods at the front (block off plate and some dremel). Now i am full cold air intake but i want to do some dragy (60-60 & 100-200 km/h) to test if there is any advantage except sound.
