Rear ARB
St3f!
257
Has anyone fitted 1 of these?what is the difference like ! gonna fit the front this week along with coilovers and wonder if it is worth while getting one for the rear also?
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Yeah, i've got one!
Along with the spacers, coilovers, strut brace and front ARB's it makes a great package! :)
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
£200 is a bit steep, if it was £100 people would be more tempted, does make it more level and handle well in the dry, in the wet it tends to stiffen it up too much!
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Yep, I did mine when changing to coilovers, the bushes had worn out anyway so cheaper to buy/fit at the same time.
St3f!
257
thought 200 was a bit steep this can be put towards the wheel fund!
Pigeon142
137
I found rear ARB is great with the standard suspension! Less impact with uprated suspension?? bit too much oversteer??
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
I always thought the Ibizas at least had a front ARB :confused: Need to add that to my list then..
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
^^^^^^^^ :lol: ^^^^^^^^ front arb is 21mm on the cupra 19 on the lower specs and on the vrs skoda is 22mm iirc cant remember now :redface:
eibach do a 24mm front arb tho!
is no rear arb as standard. the rear arb upgrade is a custom fitted part
T. Spark
I believe the FR had a extra mm over the Sport PD130's
I have the Eibach fron ARB, Cupra bushes and Powerflex bushes (best of both) and Jabba rear arb, with Eibach coilovers, 20mm rear spacers and even some iccle 7mm spacers for the front, of course running decent tread aswell all round.
I find that it oversteers and the back end does like to step out... which is great :)
Ric 2001
Need an ID-ten-T form
£205 for this rear ARB...
