Tom03
Vorsprung Durch Technik
Feb 28, 2010
347
Retford, Nottinghamshire
Hey guys,
How on earth do I replace these bulbs?
I tried to take the cover off with a flat screwdriver but I'm scared of damaging the bodywork!
Is there an easy way of getting these covers out? (Pictures would be nice!)
Thanks!
Went out and took a couple of pictures for you. Just on my phone so there're not great.
There should be a black surround and then a clear plastic cover. You shouldn't be near the paintwork because of the black surround.
This was the passenger side one and the catch thing is on the left. I used a breadknife to open the catch. It's just sort of like the battery cover on a tv remote.
Once unclipped it should come down easy
This is the cover off
If you just have a look up at it you should see it all.
Hope that helps.
After much concentration and determination I finally did it! The clips were really dug into the black plastic cover, thats why I couldnt see it, it was just a gap for me. I had to angle my head in such a funny way to see what was going on!
Thanks for your time and taking pictures!
Sent from my GT-I9000 using Tapatalk
What size are the bulbs?, am thinking about getting led's but i dont know what mm length that are.
Does anyone know if it's illegal to have the numberplate lights red?
Yes, must be white.
SCHEDULE 15
(Regulation 18)
requirements relating to obligatory rear registration plate lamps
1. Number:
Such that the lamp or lamps are capable of adequately illuminating the rear registration plate
2. Position:
3. Angles of visibility:
4. Alignment:
5. Markings-
(a) A motor vehicle first used on or after 1st April 1986 and a trailer manufactured on or after 1st October 1985:
An approval mark
(b) A motor vehicle first used before 1st April 1986 and a trailer manufactured before 1st October 1985:
No requirement
6. Size of illuminated area:
No requirement
7. Colour:
White
8. Wattage:
No requirement
9. Intensity:
No requirement
10. Electrical connections:
No individual requirement
11. Tell-tale:
No requirement
an E approved LED might be E marked but is e marked for use in a fitting that has been designed for use in a LED fitting and E marked as such
