Rear Number Plate Bulb Fitment Removal
Tom03
Vorsprung Durch Technik
Feb 28, 2010
347
Retford, Nottinghamshire
Hey guys,
How on earth do I replace these bulbs?
I tried to take the cover off with a flat screwdriver but I'm scared of damaging the bodywork!
Is there an easy way of getting these covers out? (Pictures would be nice!)
Thanks!
Went out and took a couple of pictures for you. Just on my phone so there're not great.
There should be a black surround and then a clear plastic cover. You shouldn't be near the paintwork because of the black surround.
This was the passenger side one and the catch thing is on the left. I used a breadknife to open the catch. It's just sort of like the battery cover on a tv remote.
Once unclipped it should come down easy
This is the cover off
If you just have a look up at it you should see it all.
Hope that helps.
Tom03
Feb 28, 2010
347
After much concentration and determination I finally did it! The clips were really dug into the black plastic cover, thats why I couldnt see it, it was just a gap for me. I had to angle my head in such a funny way to see what was going on!
Thanks for your time and taking pictures!
Sent from my GT-I9000 using Tapatalk
Irek
driven by bjx 1.8t
Feb 5, 2013
24
Ayr
What size are the bulbs?, am thinking about getting led's but i dont know what mm length that are.
apr95
Obd Eleven programming
Jul 21, 2014
55
10
Does anyone know if it's illegal to have the numberplate lights red?
Badger
2,888
7
Newcastle, Staffs
Yes, must be white.
SCHEDULE 15
(Regulation 18)
requirements relating to obligatory rear registration plate lamps
1. Number:
Such that the lamp or lamps are capable of adequately illuminating the rear registration plate
2. Position:
3. Angles of visibility:
4. Alignment:
5. Markings-
(a) A motor vehicle first used on or after 1st April 1986 and a trailer manufactured on or after 1st October 1985:
An approval mark
(b) A motor vehicle first used before 1st April 1986 and a trailer manufactured before 1st October 1985:
No requirement
6. Size of illuminated area:
No requirement
7. Colour:
White
8. Wattage:
No requirement
9. Intensity:
No requirement
10. Electrical connections:
No individual requirement
11. Tell-tale:
No requirement
an E approved LED might be E marked but is e marked for use in a fitting that has been designed for use in a LED fitting and E marked as such
