I recently purchased some 15mm "Hubcentric" rear spacers for my car, however since fitting them I'm getting all sorts of noises coming from the rear of the car.
Really loud squeeling when I reverse
A real Gentle knocking coming from the rear
Sounds like something is catching on one of/both of the rear wheels - the noise speeds up when I go faster, slows down when I go slower etc.
I've taken the wheels and spacers off today - can't see anything obvious that could cause the noise - so reapplied the spacers with a thin layer of copper grease to try and reduce any possible metal on metal grinding.
The bolts I've used have the same sort of end as the standard ones, ie not tapered off and fit in the sockets perfectly.
I went for a little drive after reapplying the spacers, and i'm still getting all my noises.
Obviously I'd prefer to find the cause of this and fix it, as the car looks great with the spacers on - id rather not cut my losses and remove them completely!
Anyone got any ideas?
