RS6
Nov 24, 2009
1,110
Looking at getting a Revo remap in October time! tbh can't wait! almost ready just need a full exhaust system, where am i up to engine wise as to stage 1 or stage 2 mods??
Mods done so far
Forge TIP
Forge 007p
Green cotton pannel filter
next month will be blueflame full system catback or miltek hiflow sports cat undecided as to which one at the mo
can't afforf the FMIC just yet that maybe ignored till after the map
mines a 210 btw
thanks all :)
Mods done so far
Forge TIP
Forge 007p
mines a 210 btw
thanks all :)
Stage 2 if you go for the Milltek downpipe, otherwise you're stuck with stage 1. The standard CAT is very restrictive.
Thanks for your help
Does anyone know if the the miltek downpipe is inculded in the miltek system
obviously i will have to check. don't know if anyones ordered from here before?
http://www.jkm.org.uk/performance/milltekseat.htm
i would love to get the fmic but they are big money sadly i won't be able to wait long enough would it affect the result much hoping the standard intercoolers would be ok for now, just a new FMIC would give lower temps
thanks dan!
what have you got on yours exhaust wise?
and did you get your stage 2 after fitting the forge intercooler?
I have a full milltek with de cat , standard down pipe I want the pipewerx one tho so may get that , I waited till I had all my bits fitted ready for stage 2 so fmic was all ready fitted , if you have it fitted after the map you won't get the best from it as the mapper can't use as high bost settings etc
dan i just about to order a fmic 2nite. im going for the tx kit, so i take it its ok to fit on a non mapped car, its going to be a few months before i get mine mapped.
also did you get any gains when yours was first fitted?
Yer it's fine I had all mods fitted for a good few months befor my map , i made 233 bhp on the rollers with stage 2 mods with out the map so yea gained a bit from 210
nice one m8 :)
do you know anything about these tx intercooler kits? last thing put a link up for your facebook so i can add you :)
It looks ok the smaller forge one is bigger than that it comes above the crash bar altho size isn't everything lol , give it a try mate
im sure i read that the intercoolers are double the depth on the forge cooler. just want to make sure im buying the right bit of kit. cant afford the forge kit atm
re-map
Hi
I was told I couldn't have stage 2 by Revo unless I got a high flow down pipe & fmi, they said there woud be no point? Got the downpipe in the boot (Piper to go with Milltek) but none of my mates will fit as they said it's a bitch job on the lcr, more money for fitting:cartman:
It's not that hard to fit if you can get under the car , the more you do befor a map the more power you will make I made 285 with out a downpipe
