Remote Locking Not Working
shaftoledoTDiSE
Hi Guys
I have looked through lots of different posts on this subject and tried all of the tips I have seen on here. I have had my 99 (T) Toledo SE TDi for a week now and the remote doesn't work.
Most of the guides on here tell you to keep the lock button pressed whilst pressing the unlock button 3 times.
I don't have a lock or unlock button, I have a blank button (nearest blade) and a button with an embossed key on it. Inside, I have the glass tube transmitter type. Both light the LED (situated between the buttons) when pressed and it flashes 3-4 times per second when held down. I have changed the batteries so I know they are ok.
I get no recognition from car locks, horn or car lights when I try the various methods posted. I have VAG COM but haven't the nerve to try it for key programming as I've read you can disable the key completely and the guide I read was a bit vague! (At the moment it works the central locking, starts the car and I think works the immobiliser as indicators flash when locking.)
If anyone has an idiots guide to the procedure using VAG COM, I would be eternally grateful, or any other ideas for that matter.
Thanks.
shaftoledoTDiSE
Thanks for the reply Fl@pper, which do you think the unlock button is on my key? The blank or the key button? Or can I try the procedure from scratch with either?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
blank is unlock
key logo'd one is lock
thats if my memory serves me right :)
shaftoledoTDiSE
Just tried the steps, with both buttons from scratch. Tried with all windows down and car unlocked... no joy :cry:
Thanks anyway Fl@pper.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
check the voltage of the batteries to ensure they are at least 2.9v each
or better still change em anyway
PS- windows down is just to make sure you dont accidentally lock your keys in the car ;)
shaftoledoTDiSE
Do you know if the VAG COM procedure is just for the central locking/starting or does it program remote locking also?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
theres 2 iirc
one for the immobiliser in the ecu and one for the remote via central convenience
shaftoledoTDiSE
Do you think this is the problem, or could it be the circuit board faulty? Like i said in my original post, I'm not very experienced using VAG COM and am worried I'll mess the key functions completely. Or, is this procedure purely for remote locking/unlocking?
shaftoledoTDiSE
How much did it cost jiege?... Scrub that, just seen where you are from! Should lay off the Stella when I'm posting I think!!
Fl@pper, any chance you could have a go at my key if I drive up to you please? It would give me a good excuse for a run out and is not too far from me!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i'll be honest your not the only one - all my fiddling was usually 1552 - had vag com to play with the mk2 for 5 mins but theres naff all you can use it for really on them - sorry
shaftoledoTDiSE
ok fl@pper no probs, looks like another dealer con job could be on the cards [:@]
