Remove CD changer in Toledo TDi 2003
AP2000
Toledo TDi 130
Apr 12, 2007
90
Midlands
I've just brought a Seat Toledo Tdi 130 SE (2003) and I want to remove CD changer as it will not work on my H&B CA-5555 CD/MP3 Car Stereo.
How do I go about removing it?
Also, I've ordered the facia and PC5-52 Amplified aerial adaptor. Will I need a further wiring loom so I don't loose the memory from the stereo?
Thanks.
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
You wont need another wiring loom you'll just need to swap the ignition and permenant power around (red and yellow) these should be on the aftermarket stereo wiring loom and should be easy to do
Nov 27, 2006
1,204
www.cardomain.com
The changer has a trim plate that just pulls away and you'll see the two ... T25 I think :confused: torx bits that hold it in
You can just unplug it and stow the wiring down the back somewhere, but you'll be left with an attractive hole in the glovebox
SEAT do a tray to fill it (which came fitted to models without factoy-fit changers) ..... think they're sub-£20
SWANSWAY CUPRA Dealership
