Hi all, i was out earlier trying to remove the door lock barrel, i loosened the screw in the side of the door but the barrel wouldn't budge. I loosened the screw more than recommended in the delocking and vwvortex guides but the barrel is still solid not even slightly loosening. I searched to see if anybody had a similar problem but every one's seemed to come out without a problem. I've just read over the delocking guide and it says to pull on the handle while loosening the screw, does it make a difference if you pull on the handle or not. If anyone could shed a little light on the subject it would be greatly appreciated.
