Removing the door handle??
EMM4
Please could someone tell me how to remove the external door handle on a mk2?! :confused:
Its basically broken and I've found a fixing kit but need to get the handle off to replace it!
I've got as far as taking the interior panel off :doh:
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
i was under the impression that there is a grommet round the door inline with the barrel area-ish . then a bolt behind this? undo it and slide the lot out? could be wrong though
Mckellar
There is a wee rubber circular gromit 1/2 way down the side of the door panel, u pop that off and behind that is an allen bolt.
Find the correct sized allen key and undo the screwn, once thats out its just a case of wiggling the handle from the outside and it will come out with the barrel and what looks like a metal lollypop stick lol
EMM4
Cheers guys I've got that far now :D
Do you know how the otherside of the handle comes out? I've undone all of the bolts and the side with the lock is lose but the other side is stuck?!?
Kai_1600
Shallow
Dec 10, 2005
410
Manchester
You undo the allen bolt and then slide the whole handle towards the front of the car, it should move forwards about 1/2 an inch then you'll be able to pull the side with the lock towards you and then slide the front out.
Reverse that to put it all back :)
(it took me a while of wiggling to work all that out)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
pop grommet inside door edge
undo allen bolt
pull handle towards you so lock section comes away from panel and sort of guide it up and over the door catch finger tab
slide towards back of car to release front part (sort of slid in sprung loaded)
refit is reverse as usual
dont refit trim yet as you'll need to scoop out all the broken bits out the bottom :)
EMM4
Thanks everyone!!! Its all out now....just got to put it back together :headhurt:
GrizzlyUK
You should keep them off... Smooth em down... and put a popper door mech in...
