Afternoon all,
I've located a vacuum leak on my cupra (180 auq), it's one of the breather pipes under the inlet. It's a short pipe, 130mm, it's got a id of 10mm and steps up to a id of 15mm for the last 25mm and on the pipe is the following number: 06A 103 221 AF.
Next to the rocker cover is a y-section, one of the breather pipes goes into the rocker cover and the pipe that continues on then goes under the inlet into a t-section. This bit of pipe comes off this t-section.
Has anyone got a diagram of the pcv system (I think that's what it is called) and am I able to replace it with a silicone hose?
Ed
Ed
