Replacing front wing
J.Topaz
MPG addict
Nov 5, 2006
99
I need to replace my nearside front wing as my current one is a bit dented.
The new wing is sitting in the shed and I wouldn't mind trying to fit it myself but I have no idea where to start? Do you guys think it's an easy DIY job or should I leave to the professionals?
J.Topaz
MPG addict
Nov 5, 2006
99
Found the answer.
"It will just be bolts, 10mm at a guess, bumper, head light and sideskirt will more than likely have to come off"
"correct, all bolts - mostly covered in underseal
you will be lucky to reuse the existing wing - but basically remove front bumper, remove arch liner & then undo all the bolts you can see
mind the door when you take the wing off, else you'll scratch that too
pretty easy to do though"
Seems simple enough. I'll give it a go at the weekend
