Replacing front wishbone bushes
markarse
66
Hi guys.
Do you need access to a press to remove the old or fit new bushes?
Thanks in advance,
Mark
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
yes, but it's probably cheaper & more sensible to buy a new wishbone with the bushes pressed in
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
then you need a big press
Might be adviseable to get em welded in too depending on the fit.
it's a horrid job though! I failled with a hammer, and a vice
markarse
66
Thanks for the info - is there actually any REAL benefit for Powerflex over OEM? i.e. is it worth the additional (serious) hassle to go for the 'uprated' ones for a daily (albeit 'sporty') driver?
I can get access to a press at work, but want to be sure that it is actually worth the effort before embarking on it...
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
good, new OE ones will make for a nicer day to day drive. Hard bushes make for nicer handling for the odd occassion you are pushing that bit more.
either will be better than the original ones though!
WeeJase
pert
Jun 2, 2001
8,595
dubsport used to supply ones with poly bushes already installed,not sure on fitment but i know mk2 golf is avaialable(same as ???)
markarse
66
thanks for the info - will investigate availability and cost - that might well be the way to go...
