Sounds great even without the res delete!
Any differences with the dsg farts with the res delete?
Sorry mate not mine found it on YouTube im still contemplating doing it as mine sounds pretty good as standard.
Sent from my SM-G965F using Tapatalk
Reactions: bigup
You get them every now and again with a res delete but nowhere near as loud or frequent as the pre ppf cars. Mind you mine has only done 700 miles so that may change
It does get better... pops and farts, I’m on 1600 miles with res delete MY19
Reactions: bigup
For the guys that have had a Res Delete - How long is it before you get a good sound out of the exhaust, ive done mine today and its just louder than standard, no pops or anything :cry:
I know it says give it time for the baffles a couple of posts ago but they are 15000 miles
which res delete pipe did you buy mate?
also i assume your car isn't a MY2019 with GPF fitted?
exhaust needs to be hot and also in Sport or Cupra mode, at idle when car is hot, in neutral, high revs should give it some pops
I got the Vagsport one as its ment to be the best one, also doing a Turbo Muffler Delete this weekend and its an 66 Plate ST.
Ill fill it with Super Unleaded tomorrow and take it a better run get it hot and see what happens, just from vids on You Tube people start it up and give it a bit of a rev and it crackles no problem, then accelerating hard up the road it pops and bangs, hopefully it will get better with time (sooner rather than later)
Reactions: bigup
got my19 cupra res delete done from zaustworx. sounds good not as loud as pre-face lift however nice pops and bangs and overrun.
Sounds ok not sure if the results are worth the cost. I would be more keen on getting more crackle from the dsg gear changes as the stock exhaust does seem to pop.
Did mine a few months ago (manual 290 66 plate) and the pops etc were instantaneous as soon as I turned the key. I run on tesco 99 or v power and use in sport or cupra no difference in my opinion. Even from cold the pops are there.
Reactions: DOMINIC SELLY
Just cleared 1100 miles and getting much more noise from the exhaust now in sport/cupra when hot, especially changes from 2-3-4 at full throttle
Do you get more farts when gearbox is in sport mode or manual mode? (when car is in Cupra or sport mode)
Notice it most with both in sport
Probably should mention I've noticed it a lot more with the soundaktor unplugged!
Reactions: bigup
