Sile-R
96-97-98 f2 champion
Oct 4, 2007
106
İstanbul / Turkey
What resistor needs to be used to bypass the driver airbag so i can install my MOMO race steering wheel?
(ibiza cupra 98)
is steering wheel hub same with mk3 golf?
Thanx...
Yes, some kits resistance comes from within ... Mine did not come from ...
It's easy to remove the airbag light ... I think it unnecessary. It should not burn the lamp.
On some sites, "3.3ohm 1/4watt" can be found, I'll try ...
is same the steering wheel hub Golf Mk3?
does anyone know how to bypass the drivers seat airbag i have vagcom and snap on doagnostics with layest sofyware deleted all error codes .light still on know u can use resistors jus not what ohm plz help.thanx.:confused: seen so many different ways ive saw but not for 05 ibiza cupra.any info advice would b.great.....ll
:whistle:does anyone know how to bypass the drivers seat airbag i have vagcom and snap on doagnostics with layest sofyware deleted all error codes .light still on know u can use resistors jus not what ohm plz help.thanx.:confused: seen so many different ways ive saw but not for 05 ibiza cupra.any info advice would b.great.....
If you've had a 'crash' the 'crash' data is hard coded into your airbag ecu and you have to have it decoded and wiped. Vag com won't do it.
I've just bought a car that hit a pot hole and deployed the driver's seat airbag and seatbelt. I'm trying to find out what value resistor to use so I can MOT and tax the car without having to immediately buy a new seat.
