Retrofit Auto Lights (1.6 tdi SE Tech)
Jul 24, 2019
Hi folks,
Plenty threads out there on this one already so didn’t really want to start another one but I couldn’t find the answer I was looking for.
can auto lights be added to the mk3 SE Tech? I’ve got a 1.6 tdi ST. All I could find was info about adding them to an FR.
Thanks in advance.
HighFlyingBird
2016 Leon FR 1.4 150 in Chilli Red 2019 - 2020
Jan 15, 2019
250
87
Leeds
Does your windscreen have the sensor behind the mirror? You should have it if you have dual zone climate control. I didn't in my SE but mine wasn't tech pack. Easiest way to check is to see if you have a bit of black plastic trim on the windscreen behind the mirror. If the only thing there is the mirror then you don't have the sensor.
You could probably retrofit the sensor if you bought the trim, wiring loom and obviously the sensor, but it's probably more effor than it's worth as you'd have to get behind the roof lining.
